Does sheet metal stuff work in iOS apps?
david_mackenzie
Member Posts: 2 ✭
I don't seem to be able to do sheet metal on apps. When I open a part I made using it from a browser strange lines appear. I'll try searching around the site some more. If the apps are not really intended to be used for actual design and are just cool demos, that is fine, too. I get the "we need to rush features out to the mainstream before we update the apps" thingie. Thank you.
Optionsonshapemold Member Posts: 1 PRO@david_mackenzie You can edit Sheet Metal parts using the Onshape app but you will not be able to create new sheet metal parts yet. When new features are added to Onshape, they are always added to the browser first, then mobile. For development reasons.5
