Section view is not showing the internals of the view
laura_bishoplaura_bishop Member Posts: 3 PRO
I've taken a section view through a model that I have made. I was expecting to see the internals of the model with hatched lines on the cut sections - a standard section view. However, the section view is showing the end of the model with no internal detail. The section view is in the correct place on the parent view. I'm wondering whether my graphics card is causing the issue. Anyone seen this before? It's very annoying as I have to issue the drawing today!!
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 572 image
    edited March 2017
    @laura_bishop,
      Can you right click on the view and select "Show part intersections" to see if the geometry is now visible?
