Positioning of slots
peter_paton
Member Posts: 43 ✭✭
Hi all, first plunge into CAD today, a ruler and pencil man usually!
Got on ok at a basic level with a bit of frustration here and there! I was drawing a part that required two slots on the same plane, the slot tool worked fine but I had some difficulty with positioning. Can anyone advise an easy way of doing this?
Cheers, Peter
Cheers, Peter
henry_feldman
Member Posts: 136 EDU
So here is an example of a very simple slot example (base square) with a construction line constrained to the origin lines. I will create a slot, and then mirror it over the axis line. That is a simple way, but you can also do the position of the lines that make up the slots, which can be constrained to each other (e.g. relative distances/angles/etc) or mirror over a custom line you make.
5
Link to file is https://cad.onshape.com/documents/4283581ceff19c4bf3f35e47/w/ea2b120bea0bb73828283e5f/e/6dbb19fcd923b8de1d42cec9 - hope that works!
I used construction lines to help positioning but couldn’t work out if there was a way to get the slot to snap to a position. I placed them manually but it was a bit of a fiddle.
Cheers, Peter
