Aluminium profiles assembly
I started to work with aluminium profiles (Bosch 45x45), and I was wondering if you have some interesting tricks to make assemblies easier?
I don't want to represent everything, but I would like to be able to easily make the basic shapes, and be able to move/block as needed...
Thanks,
Thanks,
Jason_S Moderator, Onshape Employees, Developers Posts: 224
Take a look what I did here: https://cad.onshape.com/documents/948cc29b68727669d0135378/w/84fa001d3a23a6a5bff84dfc/e/58ab58f2dccd0539c0552886
I made connecting plates first, positioned them in the assembly, then created a Part Studio in-context to define the lines that drive the beam profiles. If I Change the distance of the entities in the Assembly, then update the in-context reference, the lengths of the profiles are updated appropriately.
Hope this helps!
JasonSupport & QA5
Hope this helps!
Jason
How would you constrain orthogonal profiles, like vertical feet on your frame? It would be nice to be able to translate the all frame along teh feet, in the vertical direction. But it is difficult to find correct Mates for this...
