Fusion 360
ho_shoreyho_shorey Member Posts: 1
How do I make the controls work like fusion 360???
    Hello,
    You can change the Onshape View Manipulation settings by doing the following:
    1. Navigate to cad.onshape.com
    2. Click on your name in the upper right corner
    3. Click on 'Manage account'
    4. Click on 'Preferences' in the pane on the left
    5. Scroll down to 'View manipulation'
    6. Change the View Manipulation settings via the dropdown to find the manipulation style you are used to (AutoCAD)
    Let us know if you have trouble with this.
