To "Coincident Constrain", or "Concentric Constrain", that is the question. (Misquoting Shakespeare)
I have always been curious why some CAD products have both a "coincident" and a "concentric" constraint.
I understand for certain types of 2D curves (those that have a center attribute, not a mid point along its length) it might be more natural to think in terms of making curves concentric versus making their respective center's coincident. Internally, I wonder if the 2D constraint solver treats them differently; Onshape's doesn't seem to differentiate between the two.
For example, even though Onshape strongly implies "Concentric" can only be used with arcs and circles...
it is possible to create a concentric constraint between the end points of 2 line segments, or a curve end point and an arc/circle; effectively it functions a coincident constraint. The only difference I have found is the Concentric constraint gives one the ability reference an arc/circle/ellipse's center point by selecting its associated curve. Maybe this is justification enough to keep it, but I am of the opinion that when an easy to use general purpose function (coincident) is available, the specialized variant should be depreciated. The benefit being less functions to learn and a less cluttered UI. Space is opened up on the toolbar to add (make visible) something else.
For those that argue a concentric constraint is important from the standpoint of capturing/expressing design intent, I wish that 2D constraints were always applied in a way that accurately reflects design intent to support the GD&T process. But the reality is that 2D sketching constraints are used as hammers to beat a collection of curves into an idealized shape that hopefully will survive reasonable dimensional change. I do not expect to see that approach change in my lifetime.
The esoteric of how to tolerance geometry to manufacture a product that still functions is not a top (a non) priority during the geometric modeling design phase.
To the best of my knowledge no CAD vendor has attempted to use a 2D sketch constraint schema to drive the GD&T process.
Onshape (at this time) does not even make available (display) the driving dimensions in a drawing. (Hopefully, we will see this functionality soon.)
TVP, Onshape R&D
It is my practice to "Use" the edges that are going to be leveraged in the sketch. This is done for 2 reasons:
1) I have found that things just work better; the result is a more consistent and predictable.
2) A "Use" curve is displayed with a thicker line width which makes it standout; this provides better communication about the purpose of the sketch curves and its dependency to other features in the part.
As I get more accustomed with how Onshape works I see that I can take shorts cuts.
If the purpose of providing the Concentric constraint was to support a "these circles are concentric" thinking, then where is the "Co-linear" constraint, which supports the "these line segments are to line up" thinking?
I guess my biggest complaint with the Concentric constraint is, that contrary to what the tool tip says, it can be used against non-circular sketch entities.
Since you seem to have access to metrics on Coincident/Concentric constraint usage it would be interesting to see if there is a consistent correlation between a concentric constraint and a true GD&T concentricity callout in the drawing.
By "depreciating" it I do not necessarily mean getting rid of it. A good compromise might be to stack it under the "Coincident" tool bar icon (along with the "Colinear"
