problem with app-bom-master and app-stl-viewer-master samples
in General
hallo,
i'm trying to understand the samples of node.js applications. i tried app-bom-master and app-stl-viewer-master.
the readme explains very well how to install the applications, so i was successfull in adding these applications to my onshape session.
if i try to use them i run in both cases in the same problem within the first "$.ajax" call:
Cannot read property 'accessToken of undefined
something i did was wrong, but i have no idea what. i didn't also no information in the documentation ...
does anybody has the same problem? any solutions idea?
thanks
matthias
thanks
matthias
matthias_gubsch641 Member, Developers Posts: 6 ✭✭
thanks mbattistello!
but clientID/clientSecret was correct, this piece of code is well documented.
in the meantime we figured out the problem, and if i read all the hints more carefully, i could have known ...
the problem was, i have defined the wrong iframe URL. i followed the gray sample text und didn't not add /oathSignin on the end of this definition. that's i never reached the login part of the sample code
i think it may be a good idea to add this as a comment to the REDME.md
kind regards
Matthias0
Can you post more of the error trace?
kind regards
Matthias
Anyway, works now thanks to your tip.
