Evaluate FeatureScript(Onshape Api). The TransientId for a newly created plane.
max_borsh
Member, Developers Posts: 14 ✭
Hi Everybody.
I want to create an extrude feature by using Onshape Api.
So, there is a great example at Depeloper portal (Feature list API -> Example 3).
But there is a way that describes how to create sketch on the pre-defined front plane. What about creating the custom one?
As far as I understand, I have to get the transientId by evaluating FeatureScript request and then use it while creating new sketch feature by passing this Id as parameter:
<pre class="CodeBlock"><code>{
"feature" : {
"type": 151,
"typeName": "BTMSketch",
"message": {
"entities": [...],
"constraints": [...],
"parameters": [
"type": 148,
"typeName": "BTMParameterQueryList",
"message": {
"queries": [
"type": 138,
"typeName": "BTMIndividualQuery",
"message": {
"geometryIds": [
"JCC" // here it is
}So I tried to create a new plane through invoking evaluate FeatureScript request (sending a script) like this:script = "function(context is Context, queries is map){ // I couldn't get Id as parameter.
opPlane(context, id + "plane1", {
"plane" : plane(vector(0, 0, 0) * inch, vector(0, 0, 1)),
"width" : 10 * inch,
"height" : 10 * inch
return transientQueriesToStrings(evaluateQuery(context, qCreatedBy(id + "plane1", EntityType.FACE)));
But I couldn't get Id for this function. Is the way how can I get transientId for a newly created custom pane?
Same question about Determining Origin GeometryId for custom vector..
Thank you in advice!
