Error when calling opSplitPart, CANNOT_RESOLVE_ENTITIES
Lee_HeskethLee_Hesketh Member, Developers Posts: 148 ✭✭
Hello all, yet again I have another error, but in a different script this time. I am creating a script that splits a part into laminations, for use when creating counter tops out of many boards for example. I am using a for loop with the variable i to do this.
The user selects the face which they want the board length to be and an edge for the direction. Then they specify the number of boards they want. I then use the edge to get the width and divide that by the number of boards. Then I create a construction plane such that its origin is offset by the thickness of each board. I am doing this in the for loop, so on each iteration, the plane offsets another thickness each time.
Then the error... I am using opSplitPart() with the target as qOwnerBody(face) and the tool as the construction plane. However, I have an error of CANNOT_RESOLVE_ENTITIES. What am I doing wrong?
https://cad.onshape.com/documents/58d26491dbd4820fd5e392c8/v/d8e57c57dc9ea9c3ec23e7cf/e/3f67a0bdb932d66d53e4aa1c
Thanks
Lee Hesketh
There are 10 types of people in the world. Those who know binary, those who don't and those who didn't expect base 3!
  • Lee_HeskethLee_Hesketh Member, Developers Posts: 148 ✭✭
    Thank you so much!
    Now, for some reason it only splits once. Any ideas?
  • leon_pootleon_poot Member, Developers Posts: 87 ✭✭
    I was wondering the same thing. I found a trick: qSplitBy(featureId is Id, entityType, backBody is boolean), and then all you need to do is loop through the planes and newly-split bodies.
    So you'd end up with something like this inside your for-loop:
    var targets;
    if (i == 1)
        targets = qEntityFilter(qOwnerBody(face), EntityType.BODY);
    else
        targets = qSplitBy(id + ("splitPart" ~ (i - 1)), EntityType.BODY, false);
    var tool = qCreatedBy(id + ("plane" ~ i), EntityType.BODY);
    opSplitPart(context, id + ("splitPart" ~ i), {
                "targets" : targets,
                "tool" : tool
    Hope that helps.
    So what would the whole for loop look like?
    I am now getting a duplicate error
    Now it works for some reason. Thanks!
