Can't make simple fillet on edge - "Failed to fillet sections" message?
josh_levine445josh_levine445 Member Posts: 7
Simple fillet on the edge of a cylinder. What I am doping wrong here? Thanks!
    Josh,
    Can you post a link to your document here?
  • jrs_spedleyjrs_spedley Member Posts: 71 ✭✭
    Looks to me like a very small part and the fillet of 5mm overlaps itself.
  • josh_levine445josh_levine445 Member Posts: 7
    @jrs_spedley Yes! The problem was the initial value was too small. Manually entering a smaller value worked perfectly. Thanks!
    @Jake_Rosenfeld Might be nice if the interaction arrow *always* appeared regardless of the initial value. Without the arrow, there is no visual way to adjust the parameter. Might also be nice to always pick a valid initial value.
    Thanks again!
