How to connect parts using revolute mate without breaking other connections
tomasz_sciurka
Member Posts: 4 ✭
Hi, here is my example:
I would like to know how to connect Part 1<10> with Part 1<13> using revolute mate without breaking existing connections
OptionsJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646Hi Tomasz!
It worked fine for me:
https://cad.onshape.com/documents/58fe6e8e3dcbbf100b269004/w/26c78702090dcdbc479e377d/e/d176c854587e0610e55d47ec
It's a little confusing because during the mating operation the longer part will visually break its other associations (only taking account the new mate you are creating), but once you click the green check mark the assembly will re-solve and everything should be fine.Jake Rosenfeld - Modeling Team5
Looks like I was trying to connect wrong parts, I am a beginner and unfortunately doesn't have any experience with CAD software but onshape is awesome!
