How to connect parts using revolute mate without breaking other connections
Hi, here is my example:
I would like to know how to connect Part 1<10> with Part 1<13> using revolute mate without breaking existing connections
    tomasz_sciurkatomasz_sciurka Member Posts: 4
    Thank you Jake!
    Looks like I was trying to connect wrong parts, I am a beginner and unfortunately doesn't have any experience with CAD software but onshape is awesome!
    I tend to hit 'Solve' before closing the mate dialog to see the final position before confirming. This was a bit odd in the beginning but after some time it's actually good to first see what you are adding to the stack and then combine new rule with existing ones.
