that works the same as platform you are to compete with PRICELESS.
Physical movements become integrated at a very low level, a change in the user interaction increases the cognitive load on performing an operation. So not only does it take longer to make the software do what you want, but it takes longer to think about what you want to achieve with the software. Being unable to customize a basic user interaction (mouse buttons) in a software that someone uses 8-12 hours a day is incredibly frustrating. It can come across as arrogant and unsympathetic to the user.
If the purpose of this software is to provide an alternative to the existing CAD products and as a product that would run in parallel with existing CAD products, you should be able to emulate the mouse behavior to reduce the cognitive load when switching back and forth. If I need to switch back and forth between software, I can't be unproductive for 10-20 minutes while my brain adjusts.
You can check this Manage account>Preferences and you can find the option in view manipulator.
I love this option...
