How to rock a part in a half pipe
I want to rock a part by tangent mates on two rounds in a ‘half pipe’. The rounds are coupled by a tangent face. When I select the rounds one by one OS sees these rounds and the adjacent faces as one face and the tangencency behaves strangely (part 2 aligns at the flat surface).
When I move the adjacent straight faces a little bit (so breaking the 'tangency' between the two rounds) then everything is OK.
Also look at https://cad.onshape.com/documents/205b989eb647be35c6cd5d6c/w/fb11df06a4c02fea2d63ef92/e/3b6f196c0bc30c138e35ebbe.
How can I make it work without moving the straight faces.
Optionsmahir Member, Developers Posts: 1,292 ✭✭✭✭✭There may be a simpler solution, but here's how I got it to work.
- Create dummy surfaces in the part studio using Offset.
- Import the surfaces into the assembly.
- Mate the surfaces to the original part surfaces using Fasten.
- Apply tangent mates to the separate surfaces.
https://cad.onshape.com/documents/0b248696c976765029d8a061/w/0186679472f4185dc4ac36fb/e/83bc3bb78cb30692f4257662
6
https://cad.onshape.com/documents/5ac6c7b9d00ebca76cb3f0f3/w/b7a78f9c6d2cfdd04daaae7d/e/80b01e855344ea5b57e252d6
@jon_sorrells and @mahir thank you for the tips. The first is the easiest, the second the most flexible one. It can be used not only on circular but also on surfaces with a different shape.
However, both these are workarounds. It should be better if OS had the possibility to select a complete ‘tangencied’ surface or only one element of it.
