How can I create and ellipsoid?
luis_suarezluis_suarez Member Posts: 4
Hi, can someone please teach me how to create an ellipsoid in onshape?
a=25mm b=50mm and c=12.5mm
Thanks in advance, I've been trying for hours with no luck
  • anton_bertaanton_berta Member Posts: 3
    Hi Luis,
    create a new Feature Studio,
    then add the following lines:
    annotation { "Feature Type Name" : "elipse" }
    export const elipse = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
        {   definition.center=vector(0, 0, 0) * millimeter;
            definition.radius=vector(25, 50, 12.5)*millimeter;
            fEllipsoid (context, id + "elipse", definition);
     so at the end you should see:
    FeatureScript 581;
    import(path : "onshape/std/geometry.fs", version : "581.0");
        precondition
    581 may be replaced automatically to another value, this is done automatically by Onshape.
    Now click CTRL-S to commit your yust created new feature,
    Go back to part studio and add your user defined feature, called "ellipse".
    (Find it on top right under "Add user defined features" (sorry can not tell you exact wording, my UI is german).
     It looks like "{a cube}v" on top and rightmost of features).
    To change size and position, simply edit your feature studio at definition.radius and definition.center.
    If you need it often with different values it will be better to write an additional dialog for it were you can edit parameters.
    God luck
    Stephan
  • mahirmahir Member, Developers Posts: 1,319 ✭✭✭✭✭
    edited May 2017
    This isn't in the FeatureScript section. I could be wrong, but I don't think he wants to write any code. I believe he just wants to model an ellipsoid. See below. The simplest method I found was to just model a sphere and use the Power Scale Featurescript to stretch it non-uniformly.
    https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/f5faf06679376b2f43a78b84
    Another method would be to Loft an ellipse sketch to a point and then mirror the resulting surface/part. Since the tangency can be adjusted, this wouldn't yield an exact ellipsoid, but it would get you something close that would let you tweak the shape if necessary. An actual ellipse on the other hand only has 3 dimensions (not including positioning/rotation).
    He shall not write code, but yust copy it.
    Its not complicated at all.
    BTW, where do you hide your PS?
    edited May 2017
    I'm not saying he shouldn't write code. If that's what he wants, more power to him. It just didn't seem like a coding question.
    Someone posted the Power Scale feature on the forums a while back. Here's the link.
    https://cad.onshape.com/documents/c3f3651d28491d28eefba7d3/v/167ba220d329f5bec671e716/e/dbc28ecb5a20b4bfa14fc748
