Creating a plane inside a sphere
Al_BostonAl_Boston Member Posts: 2
edited May 2017 in Community Support
Good day, I am attempting to create a plane inside of a sphere, however I need it to be turned slightly, I need it through the sphere at a 45 degree angle, so rather than following any of the XYZ planes, I need it 45 degrees in between x and y. A
  • mahirmahir Member, Developers Posts: 1,320 ✭✭✭✭✭
    Start a sketch on the Front (XZ) plane. Draw a vertical line that will serve as your reference axis for rotation. Start a new plane feature with the Line Anglel option. Select the Top or Right plane and the line you just sketched. Enter 45 deg. Complete the feature.
