Why do you guys think this would happen to my 3d print?
asterios_anagnostou
Member Posts: 17 ✭✭
Hey guys, I'm a little new to this and my documents are still coming out a little weird when I 3d print them. I'll attach a couple pics here so you can see whats happening. I am printing with a DaVinci 1.0A, stock. Thanks for any help you guys can render! https://cad.onshape.com/documents/3de4aff6ac3721cf0b82c0d8/w/eee0d6d23d87ae2d3ec45dd4/e/bc8e7155baf677cb2b348715
-Asterios
-Asterios
Optionsowen_sparks Member, Developers Posts: 2,660 PROHi. Looking at a cross-section of your part you've got some voids, almost a box withing a box. Is that deliberate? There are some pretty thin walls...
HWM-Water Ltd1 -
Optionsowen_sparks Member, Developers Posts: 2,660 PROHi @asterios_anagnostou, no problem, happy to help. You'll have to give me a few hours, need to sort to work first. If anyone else is free please jump in.
1st thought though is you're over-complicating things. I'll be back.
HWM-Water Ltd5
Realiz3D.in
-Asterios
P.S. How did you cross section the part???
P.S.S I just accidentally broke one of the walls on the side. You're definitely on to something with the walls being too thin! Lol!
Cheers,
Cheers,
To stop me messing up any of your work I'll make a revision and then a branch off it, and I'll only work in that branch. Do you want the same shape but just without internal cavities? What's critical here?
Cheers,
Addition: the ledge just below the surface is supposed to support the cover so that should stay. I have trouble printing that part because of sagging, but I can just cut out the excess material.
