Modeling a finger; attempting a loft and having an issue with creating a guide line
I am wanting to 3D print a splint for my little finger. I have an injury that the doctor called a "Swan's Neck Injury" where the flexor tendon(s) have been injured. The Dr. office hand-made a splint out of a material called 'Aquaplast' which works pretty well, but I want to make a more nerdy version which has some smoother shapes and optimized strength with a little tighter bend at the 2nd joint from the tip of the finger.
The modeling approach I was going to take was to measure the bend angles I want for the joints, measure the length of the phalanxes (sp?) and model the diameter of each section with an ellipse, then loft from ellipse to ellipse, shell the loft, then apply some subtractive tools across the back side of the 2nd joint.
I should have looked more deeply into guide lines before I modeled the x-section ellipses because the guide line I did make was the center of where I laid out the ellipses on planes normal to that guide line. You OnShape pros know that the guideline can't be a centerline.
I thought it would be no problem to make a new guideline by connecting to the ellipses on an outer edge of each ellipse, where they intersect the plane where I laid out the centerline. Well, I can't make that work for whatever reason. I can't get a point to lay out where the 3 different ellipses intersect the plane where the centerline is laid out, and as a result, I can't force a line to connect to those ellipses.
Any clues? Link to my file is here: https://cad.onshape.com/documents/d002c2baef598dc443f902a1/w/2ca82884d4cd6b1e036a917d/e/9655c4bbbfe163b62062e001
bradley_sauln Moderator, Onshape Employees, Developers Posts: 373
Also, make sure to use the "pierce" sketch command, when creating your guide curves https://cad.onshape.com/help/#sketch-tools-pierce.htm?Highlight=pierce5
Have you tried the new 3d curve spline tool? You have a point at the top of each circle, I'd try a spline through those for the guide.
Brilliant project BTW
Twitter: @bradleysauln
Owen, I put those points there but I can't seem to pick them for points on the guide line.
