Re-apply attributes to patterned entities
leon_pootleon_poot Member, Developers Posts: 87 ✭✭✭
Let's say I'm (linear) patterning a couple of bodies. Some of these have been given a specific attribute using FeatureScript ({"A" : true}), some others another attribute ({"B" : true}). The new bodies apparently don't get the attributes, which I'll need for later boolean operations!
The instance count is based on a parametric variable, and there's no knowing how many instances there'll be, so I can't manually be setting the attributes for all the new instances. I'm thinking of somehow reading which parts have which attribute, and then re-applying these to each new instance.
So what I really need is to be able to query all patterned instances of a specific part. Any idea how do this, anyone?
    edited May 2017
    maybe is worth to try to obtain the id of body pattern and select all bodies created by operation with corresponding id like this qCreatedBy(lastModifyingOperationId(qOwnerBody(query_of_some_item_of_the_pattern)),EntityType.BODY)
  • lanalana Onshape Employees Posts: 731
    @leon_poot
    var trackingAQuery = startTracking(context, bodyA);
    opPattern(..)
    instancesA  = evaluateQuery(context, trackingAQuery) ;
    This should give you all the instances of bodyA created by pattern.
  • leon_pootleon_poot Member, Developers Posts: 87 ✭✭✭
    @lana That makes sense... but this would require me do the pattern by FS, I'd much rather be able to fiddle with the parts in the part studio. But I guess I could make a modified pattern script from the std library?
    Ah of course! That should do the trick, thanks :smile:
