BOM struggles.
Man..... seems like all the stuff you would think would be easy is a major struggle with this software.
I create components in parts studio that is of course ultimately made up of a bunch of different parts with extrudes and what not. So even though it is a drawing of only one real-life part, it is a bunch of parts to Onshape. When I go to create a BOM, it gives me 100 parts for my assembly that has about 10 parts in it. There's no group command in the partsstudio and I have grouped them in the assembly but the BOM doesn't abide by that grouping. You can't just delete everything in the BOM because it won't let you. So how are you supposed to get a usable BOM if it makes an entry for each "part" as defined by Onshape?
Hi Scott, sorry about the problem you have. I will try to help you.
openBOM can group parts by names. This is useful when you create BOM for design which is using Parts created in Part studio using copy / paste and/or transformation. Essentially, these are different parts in Onshape, but you want to make quantity count based on name (and not internal Onshape id).
Please let me know if it solves the problem. You can contact me at oleg @ openbom dot com. You can also use feedback button in openBOM or send an email to support @ openbom dot com.
Best, Oleg
