Point Pattern, set orientation for each?
NAE
Member Posts: 8 ✭✭
I'm using @cody_armstrong 's Point Pattern FS quite a bit. Very nice!!
Some of my patterns would benefit from being able to set the orientation of each thing patterned and I would like to add that functionality to a copy of "Point Pattern".
Something simple and click-able like the "reorient" like when placing Mate Connectors:
I can't find a reference to "reorient" anything. Anyone know how this would be accomplished?
For now I think the best choice is to make a four-state enum parameter for rotating 0º, 90º, 180º, and 270º.
Has this been implemented? I would love to use it :-)
If it's too complicated, a simplified version that may address many use-cases is to specify a surface that the features/parts should be normal to. When you select the reference point, you would also select a reference surface that the reference points sits on.
No but there is a custom featurescript called Transform Pattern which can reorient the pattern.
https://cad.onshape.com/documents/6b982e3c0a039b6d40984f18/v/127c578ceb9bd1e98f7b982e/e/faf01df33f2825fc8e751462
Forever requiring approval :(
