Mirror a sketch but don't keep original
Josy_LaJosy_La Member Posts: 82 ✭✭
I can't find if and how this is possible. I need to mirror a sketch done by someone else without keeping the original entities. Seems a very simple task but I can't make it happen??
    Once you've mirrored the sketch, either within that same sketch or in a new sketch, delete the symmetry relations. The new mirrored sketch will be unconstrained but independent of the original. You can delete the original after that if you like.
  • Josy_LaJosy_La Member Posts: 82 ✭✭
    My bad! Today I am able to delete the unwanted entities. Thanks anyway
  • moritz_vifianmoritz_vifian Member Posts: 2
    If you need to mirror the complete sketch, you can create an artificial plane with flipped normals. This way the constraints are preserved.
