Threaded Hole Patterning
gabriel_ginorio
Member Posts: 2 EDU
Hello, I created a bolt and then proceeded to create its corresponding threaded hole by using the boolean operation. I want to pattern this 4x around a circle but I can't figure out how to do it. Please help
https://cad.onshape.com/documents/24e7aa4c44fe94f6270b992b/w/e606e02d2cdf8df67f2bd519/e/6c4a040f378d5cd6951fc86b
Looks like you found Circular Pattern. Anything else you need help with?
