Why can't I copy and paste part of a sketch to a new surface parallel to the original?
sam_joelsam_joel Member Posts: 2 EDU
I essentially of 2 parallel disks an inch apart from each other. I have a geometric pattern cut in to one of the disks and I'd like to mirror that pattern to the other disk so I can make the same holes using extrude. I'm unable to simply adjust the extrude depth so that I can cut through the bottom disk from the top.
  • chris_winters404chris_winters404 Member Posts: 38 PRO
    Howdy Sam,
    Have you tried using the USE (project/convert) command?
    Make sure your previous sketch is visible so you can pick the features from that sketch.
    The shortcut key is u to enable
