Snapping
Luke_Chase
Member Posts: 8 EDU
How can you make objects (lines) in one sketch snap to construction shape in another sketch?
Jake_Rosenfeld
Hi Luke,
You can use the "use"command in your sketch to use external geometry in your sketch:
https://cad.onshape.com/help/Content/sketch-tools-use.htm
Once you "use" the construction lines from the other sketch, it will be easy to snap to them.Jake Rosenfeld - Modeling Team5
