Example create a slot feature code, doesn't go through part
When I try the example slot code https://cad.onshape.com/FsDoc/tutorials/create-a-slot-feature.html with an extruded object with a second end point in the same direction as the first the slot doesn't go all the way through the object. For an extrude of 25mm the second extrude has to be 5mm or more for this behaviour to be seen. Is this a problem in the feature script code or something else ?
https://cad.onshape.com/documents/08ada15a1289fc96819474c0/v/36c76a0ca674d0000777b7b4/e/66d098b0d2030a827df6036f
Can you link to the document where you're seeing the buggy behavior?
Here's my example
https://cad.onshape.com/documents/117a4918233922cdfb8ca6b9/w/2cc38d38ec57bbf1621e40ed/e/57dad1553f6559f5bc5d9193
I've filed a bug for you. Thanks for reporting!
