Unable to fillet edge
dylan_staley
Member Posts: 1 ✭
I'm attempting to fillet the edge of a triangular-shaped extrusion, and the fillets aren't generating. I used the same approach in a previous version that worked correctly, so I'm not sure what I'm doing differently this time.
Here is a link to the document, and below is a photo of the edge I'm trying to fillet along with a photo of the previous version.
https://cad.onshape.com/documents/831fc92dbc88c8e53f1a630d/w/2698677764ce0c1cc1b9b8c7/e/7e03ec4d89bfca40652f4977
Could you report this issue with the "Feedback" option under the "?" menu in the top right corner of your Part Studio? Looks like a bug (especially if it used to work correctly); we would like to investigate.
Clicking again on the same line and attempting to produce a fillet has this result...
That seems to look like the correct result but the entity to fillet is now "Edge of Fillet 1" and a new fillet, "Fillet 2" has joined the features list.
