Pattern of holes through a cone?
donovan_magrytadonovan_magryta Member Posts: 5
edited June 2017 in Community Support
Hi,
I am trying to make a pattern of holes through a cone all going the same direction, but the fill pattern feature script doesn't seem to work with cylinders or cones.
What should I do?
    edited June 2017 Answer ✓
    Hi Donovan,
    There were a couple problems with your fill pattern.  First, the edge specified for 'direction' was confusing the feature.  I drew a new edge that is just flat along the XY plane and used that for the pattern direction.  Secondly, the 'distance' variable is the distance between the centers of the pattern instances. Because the patterned face had a .07 inch diameter and the pattern distance was selected as .05 inches, the pattern would basically destroy the entire cone.
    See my fixes here (feel free to copy my copy so you can see my inputs to the fill pattern feature):
    https://cad.onshape.com/documents/32f6beb4f22dfbe345102357/w/66dc199acd7a867a4166822e/e/3d27eecff8c69762370e0313
    In case you're still curious, when Philip says "normal" he is asking whether you want to drill at a 90 degree angle into the face.  The normal of a cone (looking from the side) looks something like this:
    Sorry for the crude drawing.
    https://en.wikipedia.org/wiki/Normal_(geometry)
