HOW TO USE RIP TOOL
lamberto_previati
Member Posts: 3 EDU
Hello to all,
I'm a teacher and I use Onshape in my classes.
We must shape the object of the figure. Can I use the RIP command to make the cylinder part reinforcements? And if so, how do I use the command?
Thanks for the attention.
You can definitely make this geometry in Onshape. You should look for the "Rib" feature rather than the "Rip" feature. The "Rip" feature is for creating rips in sheet metal.
Here are some resources for you:
https://cad.onshape.com/help/Content/rib.htm
https://www.youtube.com/watch?v=GN-IKLWH6x0
You could also select the front plane and use the Project convert(with the construction line feature turned on) to grab the two lines you would need to build the geometry for the supports and extrude symetrically from there. then array the feature around the cylinder and after that combine using the boolean feature.
Stay awesome!,
Sincerely,
Chris Winters
https://cad.onshape.com/documents/9f234338d696237a996a1627/w/7b32076b9c096d6676f0477d/e/e2c0fad664e55d1116904466
I also added a second model using the rib featurescript
Here you go
https://cad.onshape.com/documents/d5530b3c4f76baffcc9ddc5a/w/cf20fee629b0088d72a84953/e/51069fedb1ee09329d332e77
Best of luck!
I would stick to using the Rib feature provided by Onshape. The Onshape approved feature started as the custom feature, but now it has a place in our standard library. Stability, reliability, and performance improvements went in since the creation of the custom feature.
Jason
The rib FS solution (Jason_S post) produces a 'step' at the top of the rib feature
The solution in chris_winters404 post produces a flat interface with the circular boss....
Now either may be actually acceptable for an actual manufactured part, but the figure that was requested to be modelled shows something different...
This would have a rib with a rectangular face that is non-planar (which I thought Chris was alluding to when he wrote "They go from a straight surface at the bottom into a radial surface at the top of the boss", but his model than didn't show.
Here is my attempt.....
https://cad.onshape.com/documents/7082e5f574b254885f1a9262/w/96dc5e459fd3570954b7e7b7/e/c65b55bf47a5e8f310c3b0a6
Which is created using a loft and yields the curved rib surface and interface with circular face
