Point of Intersection.
Member, Developers Posts: 120 PRO
Is there a good way to evaluate the point at which two lines or edges intersect?
Cheers,
Darren
  • Member Posts: 1,221 ✭✭✭✭✭
    evDistance gives the minimal distance between entities, and you can extract from evDistanceResult coordinate of points, that give a minimal distance - if entities intersect each other the distance will be zero
  • Member, Developers Posts: 120 PRO
    yes, ok I'll do this. thought there might be a way of evaluating a collision for a point, but this will work. Cheers.
    as a follow up, this worked cheers @konstantin_shiriazdanov.
