Point of Intersection.
darren_13darren_13 Member, Developers Posts: 120 PRO
Is there a good way to evaluate the point at which two lines or edges intersect?
Cheers,
Darren
    evDistance gives the minimal distance between entities, and you can extract from evDistanceResult coordinate of points, that give a minimal distance - if entities intersect each other the distance will be zero
  • darren_13darren_13 Member, Developers Posts: 120 PRO
    yes, ok I'll do this. thought there might be a way of evaluating a collision for a point, but this will work. Cheers.
    as a follow up, this worked cheers @konstantin_shiriazdanov.
