Trying to add units and bounds for velocity... am I missing something?
darren_13
Member, Developers Posts: 120 PRO
So I have this code:
This is based on the std featurescript, but I get all sorts of errors such as:
-Expected parameter id to be defined as a field on value
-Unexpected operator (EQUAL_TO) in feature precondition
-No matching predicate declaration for verifyBounds (I copied and pasted this in to be sure)
I don't know what is different between the std and what I tried but I seem to have messed something up
https://cad.onshape.com/documents/95877be3b17f49277e87a2c3/w/b503830fd20472014beb1221/e/034312f7fdec452704158115
folder Twist Calculator, feature scripts; Twist Calculator, Units
Thanks,
Darren
export type VelocityBoundSpec typecheck canBeVelocityBoundSpec;
export predicate canBeVelocityBoundSpec(value)
canBeBoundSpec(value);
@size(value) == 1;
for (var entry in value)
isVelocity(entry.key);
* True for any value with velocity units.
export predicate isVelocity(value)
value is ValueWithUnits;
value.unit == LENGTH_UNITS/TIME_UNITS;
export predicate isVelocity(value, boundSpec is VelocityBoundSpec)
isVelocity(value);
verifyBounds(value, boundSpec);
export const VELOCITY_BOUNDS =
(meter/second) : [0, 100, 299792458]
} as VelocityBoundSpec;
Thanks,
Darren
Many thanks,
Darren
