Magnitude of value with units
How to extract unitless magnitude of value with units if the units are unknown? Or what is internal structure of ValueWithUnits type, is it of map type?
  • paul_chastellpaul_chastell Onshape Employees Posts: 126 image
    edited July 2017
    I would suggest you divide by the unit you are interested in, and ignore the internal representation. If you have a length and what to know how many meters it is then you can do "var lengthInMeters = length / meter". It doesn't matter what unit 'length' has. Or "length / inch" to get the length in inches. In both cases the result is a unitless value.
    E.g. this custom feature measures the distance between two points, in inches, and logs it to the console
    <div>annotation { "Feature Type Name" : "Distance in Inches" }
    </div><div>export const inchDistance = defineFeature(function(context is Context, id is Id, definition is map)
    </div><div>&nbsp; &nbsp; precondition
    </div><div>&nbsp; &nbsp; {
    </div><div>&nbsp; &nbsp; &nbsp; &nbsp; annotation { "Name" : "Points", "Filter" : EntityType.VERTEX, "MaxNumberOfPicks" : 2 }
    </div><div>&nbsp; &nbsp; &nbsp; &nbsp; definition.points is Query; &nbsp; &nbsp; &nbsp; &nbsp;
    </div><div>&nbsp; &nbsp; }
    </div><div>&nbsp; &nbsp; &nbsp; &nbsp; if (size(evaluateQuery(context, definition.points)) == 2)
    </div><div>&nbsp; &nbsp; &nbsp; &nbsp; {
    </div><div>&nbsp; &nbsp; &nbsp; &nbsp;     var result = evDistance(context, {
    </div><div>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; "side0" : qNthElement(definition.points, 0),
    </div><div>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; "side1" : qNthElement(definition.points, 1)
    </div><div>&nbsp; &nbsp; &nbsp; &nbsp;     });
    </div><div>&nbsp; &nbsp; &nbsp; &nbsp;     println("Distance in inches is: " ~ (<b>result.distance / inch</b>));
    </div><div>&nbsp; &nbsp; });
    </div>
    Paul Chastell
    TVP, Onshape R&D
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,253 image
    Paul is absolutely right.  But if you're curious about what the representation is, you can look at units.fs in std or do println("" ~ inch);
    ok, thank you Ilya and Paul, I found out that ValueWithUnits is internally a map and "value" field contains magnitude
