New FeatureScript: Full round fillet
emagdalenaC2i
Member, Developers, Channel partner Posts: 867 ✭✭✭✭✭
Hereunder you can find a link to a new FeatureScript to create full rounded fillets.
https://cad.onshape.com/documents/3d52520839c0fa3587798c0f/w/2c36a47f3c428c7a3f8e3a5f/e/d04263a8cc0e773b0f18b0b9
You can test it in two flavors:
- C2C Full Round Fillet (A separated feature to create full round fillets)
- C2C New Fillet (The same feature but integrated with the Onshape's standard fillet feature)
Un saludo,
5
Nice work, I often want this feature and the 2 edge method rather than the 3 faces works well and is quick, however, I wonder if a 3 face selection could also be an option?
I'd love to see this or something similar incorporated into the standard fillet tool.1 -
I've thinking of that but finally I asked myself... why?
You need 2 extra things that you really don't need:- One more entity selection
- Rotate the view almost all the time so you can select the 3 faces
You can see it working in the "custom" standard fillet I have created --> Look at the Part Studio "New Fillet samples"Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común1 -
I definitely prefer 2 edges too. It saves the rotating and extra select and I can't see where 3 faces would have an advantage over 2 edges0
Due to the improvements in the fillet feature released in the last version of Onshape, we have edit our "C2C NewFillet" feature.
With this "C2C New Fillet2" feature you can create:- simple fillets
- variable fillets
- and full fillets
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común4 -
It's not working on non parallel edges for me.0
please, could yo share here a public document?Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común0 -
Hi Eduardo,
Here is a link: https://cad.onshape.com/documents/e5a7756a2e010d30dabb9b8d/w/75d097e96d772acfe6397150/e/4035f83e7948fddd32ea93c60
