Onshape CAM?
christian_lewis
Member Posts: 5 ✭
in General
Hi Everyone,
I'm just entering the CNC machining world, I've been following it for a number of years but never had the money or the time in the right combination to get a machine and use it, but now I'm attacking it at full force. Anyway, I'm trying to sort out my software packages and I really really like Onshape so far, it can already do most of what I need so it's likely going to be my main/only CAD software. However, I have a problem - the price of CAM software is (lets be honest) a massive investment for software for a beginner machinist unless I can work with one of the questionable free products. So I was wondering if the Onshape team has any plans to extend into the CAM process in the future. Obviously that future is far enough away that I'll have to settle for something else for the meantime, but I'd really love to see the Onshape team revolutionise CAM in the future, so how about it?
Thank you so much for what you're doing to CAD, I love it.
Meshcam has a trial and retails for $250 - which I think is quite a bit cheaper than other solutions though I've no doubt that it has limitations that more expensive products don't have.
Onshape has announced partnerships with Mastercam & Solidcam (https://www.onshape.com/partners/technology) however there's nothing I can say beyond what's already on the website.
$250 is far cheaper than even the low end of everything else that I've seen, I'll certainly give Meshcam a good go. Hopefully it's the solution for me.
Oh, okay. That makes me feel confident that there's going to be something happening here with CAM as well.
Dave
Ariel, WA
aicher@battleaxe.com
Tigard, OR
http://www.spiked3.com
So I guess I don't really have a specific question from this point I know I'll likely have to fork out a bucket of cash for 4th axis control (maybe Sprutcam? I watch a lot of 'NYC CNC' on youtube), I'm just open for anyone's ideas and brain candy on the topic and so this thread can be handy for anyone else in the same position. So again, thanks for the advice everyone.
Get a good CAM package and learn it well. I use Espirit by DP technology.
In regards to your screw driver handle- how many you are making? Production run: That is a 3 or 4 axis lathe job with one setup.
If you are only making a few hundred….use a hex block and rotate the part. Hex block= $50 and you can complete the part indexing in two days on 300 of those parts. You could also drill through and only rotate the part 3 times. Put the chamfer on by hand when you deburr.
You could also use a step drill and drill / chamfer in one shot. The cross pilot from Mikron is designed to drill tangent to a cylinder and won't push off.
Does your mill have spindle orientation? IF it does you should chuck the part in your spindle and mount a live tool (drill) on your table and complete the hole pattern without paying for a 4th axis setup.
Stay away from PCNCs. Instead, get used quality machine tools.
What about changing the features to a honeycomb? Don't change them to a honeycomb until you are setup correctly to machine them.
The CAM that guarantee that the tool and machine will be used in optimal condition.
Dave
Ariel, WA
@david_sohlstrom I am happy to hear sprutCAM9 and the Torch 770 are working for you! Its a great time we live in where we can leverage technology to make amazing things and turn ideas into actual things!
I am certain Onshape is going to be a game changer in our industry.
