FeatureScript to update part appearance and name?
mbattistellombattistello Member, Developers Posts: 51 ✭✭
Is it possible to update a parts appearance/color and name using FeatureScript? I looked thru the docs and dont see a way. I also updated a part and checked the code and dont see where its showing up so Im guessing these types of changes are not considered features.
I am able to add in an attribute to the body but that doesnt seem to have any impact on the display. Maybe there is some attributes to specific to these values?
    ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,180
    It is not currently possible, but hopefully we will have this in the not-too-distant future.
    A related question. If I used setAttribute to set a value on a body is that value available in the API? I tried to find it but dont see it. I thought it might show in the feature list (/partstudios/d/:did/[wvm]/:wvm/e/:eid/features) but I dont see it.
    If I can "tag" the body in FS then in the API I can make the appear and name using the API and a webhook.
    It doesn't show up in the feature list, but you can get access to it from the API by using the evalFeatureScript API ( /partstudios/d/:did/[wvm]/:wvm/e/:eid/featurescript ) -- just pass a function that takes the context and reads/queries for attributes from it.
    @ilya_baran could you help me with the featurescript to use in the api call?
    Im trying this but it doesnt work.
        "script": "function(context is Context, queries){ return getAttribute( context,{ \"entities\": qEverything(EntityType.BODY)});}",
        "queries": []
    The first thing I see is that the function name is getAttributes not getAttribute.  I would suggest testing the code first in a custom feature at the end of the part studio -- that will iron out issues with the FS.
    I dont see a getAttribute in the docs? Only getAttributes - https://cad.onshape.com/FsDoc/library.html#module-attributes.fs
    I have a FS that sets the attributes and then I pull them and dump via println so they are getting set. Using API Explorer to try and get the FS correct but doesnt seem to work. I can get some of the sample code working.
    Yeah, that's what I am saying: your script above has "getAttribute" instead of "getAttributes".  There is no getAttribute in the library that I can see.
