How to align a rotated part with extruded part
tgunr
Member Posts: 45 ✭✭
New to onshore so be gentle. I have a simple sketch with 3 parts. The first part is a full rotation on the right axis with a radius of 6mm. The 2nd and 3rd parts are extruded blind and pulled out to 6mm. When viewing the model the rotated part does not match up with the extruded parts, It is about 1.1mm larger than the extruded parts. How do I get the extruded parts to align with the boundary of the rotated part?
Jake_Rosenfeld
I believe he solved his own problem: https://forum.onshape.com/discussion/7023/how-to-align-extruded-parts-to-rotated-partJake Rosenfeld - Modeling Team5
