cycloidal gear animation
How do I get this cycloidal gear to animate in the same way as in this video https://youtu.be/guvatctnjww?t=194 where the inner cam(yellow) turns ten times for every one of the grey gear. It would seem I would need a tangent relation with a relation ratio ?
don't know what kind of kimatics generates the outer profile but I have an example of cyclo gear when cylindrical teeth are stationary in the housing. anyway there are no fundamental difference between evolvental and cycloidal gearing since its all about rolling of cylindrical surfaces, so you need to use gear mate with corresponding ratio
https://cad.onshape.com/documents/a0adddcc041efb15f8c3ad2a/w/4e997c4fe738a2030fa71786/e/6ad4a0108794308c4b7796aa
6
I used some code from here https://cad.onshape.com/documents/ba83d698b55b206c3363b305/w/3173b192860505117c164791/e/616651006a651403af9316a9
My project is here https://cad.onshape.com/documents/16343aeebf98d3d0b59407ee/w/9a522b966b1a0b38eb22e8ff/e/3c21c28d3ed3292a84c5762d
I am ultimately trying to model the Abacus Drive from SRI International https://www.youtube.com/watch?v=zoaHeamUqBE . I only need to have a sweep go round a circular inside and outside race following the cycloid path with a profile matching the abacus bead to get the variable width path I need.
The gear ratio can be determined by the formula: Ratio = (Pins - Lobes) / Lobes.
You are right about the gear ratio. My mistake. The ratio that I posted is actually the ratio of the final output (the red pins in konstantin's example).
