How to make rod like in photo
jafri_hilmi
Member Posts: 3 EDU
lemon1324
Member, Developers Posts: 228 EDU
Onshape doesn't have 3D sketching, so you need to define the path in multiple sketches, but you can sketch the tube centerline and then sweep the tube profile, as in this example I made:
Arul Suresh
PhD, Mechanical Engineering, Stanford University1 -
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,253
For more complicated paths, you can also use this polyline-with-arcs custom feature and then sweep: https://cad.onshape.com/documents/453c51c8807f37082c1247f3/v/9dac4678249816079b401245/e/3b555bbcf77afb0d5272cfdbIlya Baran \ VP, Architecture and FeatureScript \ Onshape Inc1
