How to use onshape with apple's magic trackpad.
Ruikai
Member Posts: 1 ✭
write something
To activate the pan or 3D rotate, the gesture is to have two fingers on the trackpad, click (and hold), then lift one finger. With the click +1 finger you can then 3D rotate, or if you hold the control key at the same time you can 2D pan.
The View Navigation portion of the help discusses it for other types of input devices.
