Question about mirroring..?
daniel_casimir
Member Posts: 3 ✭
Hi, i just started using onshape and am trying to model something, its a crate, so its a box with a sort of texture on the side. Like bars. i figured out how to use linear patterns fine, but how do i get the surface i made from one side of the box to the other? Example: http://i.imgur.com/p9iwwvo.png how do i mirror one side to another.
bradley_sauln
Moderator, Onshape Employees, Developers Posts: 373
The easiest approach would actually be to do a circular pattern to get this on all 4 sides
Take a look at my approach to your document: https://cad.onshape.com/documents/71ddade4e6487182db82d64a/w/3e3819f5ee4b4fae31e58e74/e/755aeff25fd8a74f3bcaee3e
Please take a look at the differences between part, feature, and face pattern as a face pattern of complex geometry tends to have better performance.1
Could you share your document?
Twitter: @bradleysauln
