Unable to see the constraint icons. Need help
JayakumarJayakumar Member Posts: 2
I am unable to see all the constraint Icons that I applied on my sketch entities, even though i checked the ""Show Constraints" check box in the Sketch dialog.
How to view the various constraints icons in the sketch ? Can anyone help please ?
    @Jayakumar If you cannot see it, then there is a mistake.  What browser are you using?
  • JayakumarJayakumar Member Posts: 2
    Hi LouGallo ...... I am using Google Chrome. Thank you for your reply.
    I will ticket this for offline.
This discussion has been closed.
