Multiple Variables in Single Expression
 Andrew_Yoder
                    Member Posts: 2 ✭
Andrew_Yoder
                    Member Posts: 2 ✭
                    So I was trying to confine the dimensions of a box I made with variables, so that the whole box will regenerate with target values by changing any one of the variables. Normally this would be easy, using just x,y, and z vairables. However, the dimensions I wanted to input outside the sketch were for the object entering a slot inside the box, so to change the overall dimension to the right size I added a variable for tolerance (that I could change later if the slot didn't fit) and then tried to make to make a composite variable that represented the whole length of the slot(): 2#tol + #length (naming arbitrary). Sometimes using 2 variables does work, but for the most part the computer doesn't recognize it as an expression. And this problem works with any name I could think of, single letters or long words. Going into the forum, tutorials, or otherwise, no one seems to have tried using this. How can I achieve making a CAD that changes itself to specifications just by editing the global variables, without using more than one variable?
The answer here was that he was trying to add a unitless value to a length.
