How to achieve desired motion?
Hi,
I'm trying to animate an awning via various mate connector motion but I'm missing one and can't seem to make it work. In the example below I need the front portion to make a sliding movement towards the outside but when I add this type of mate many other become red and have errors. How can I restrain the movement. Now it is all skewed because both arms do not move in the same fashion.
Can someone help me out?
https://cad.onshape.com/documents/8b02481e4674d566d2c3e285/w/f86c0b3452eb732a17b1e166/e/5cbfac7ebde9510334383ec9
Thanks,
Thanks,
Twitter: @bradleysauln
Please ignore the link tab in the share screen. Just make sure the file has the "can copy" option set and copy the url from your browser into the forum post.
Cheers,
That's the same link as your first post...
This is what we're after:-
Then copy the url from you browser after you have the file open and lob it onto the forum.
Cheers, Owen S.
Yes the two short gray are somewhat fix. They are currently attached along an edge until all other components are finalized. But they must pivot for the entire arms to extend and retract. Fascia should remain parallel to wall making the arms stretch symmetrically. Which is obviously not the case now.
I think this is close to what you're after, if I understand correctly.
I don't believe there is anything mechanical in your design that gives the parallel motion you desire. You can see this in the file below. All the mates are "real life" except the final one I've called "Parallel Motion Constraint". If you suppress this you'll see how I believe the design will actually behave.
You'll see the workaround involved a named position "Closed" leading to an in context edit of the front extrusion to allow a mate connector in the correct orientation for the final parallel mate.
https://cad.onshape.com/documents/728b88e6116bcd225777bc01/w/016c81ff94988f557808e8e3/e/d1a427315df46e9fc7c17784
Don't know if any of that is any use to you.
Cheers,
Josy
