Export dxf flat pattern with bend lines
joseph_terpend
Member Posts: 17 ✭✭
I send dxf's to 3rd party company to have parts laser cut and folded, they have recently decided that they must have the bend lines included in the dxf. Is there a way to do do this.
joseph_terpend
Member Posts: 17 ✭✭
Thanks I was a bit confused at first then realized that you do thiswhen you open the exported dxf. I also first thought this would be a pain to open every dxf and show the bend lines before sending them off to the 3rd party but then "because I am lazy" I can just tell them what you told me, "if you want to see them show them" they are there:)1
You just need to show the layers you want in the DXF file:
