Title block sheet references not updating
I can't seem to get my title block to update the auto-references. Drawing title etc.....
I right click on the tab, go into the drawing properties and fill in the lines I want but when I hit apply nothing changes.
Is there something I'm not doing to get this to work?
ETA: It's actually just the 3 title lines that don't change. The rest of the fields change when filled in in the drawing properties.
Could you make your document public and post its URL here? If you'd rather not do that you could either try to make a similar example without proprietary information and post that, or file a support ticket from the ? menu in your document and get a direct answer from our support team.
I just tired it here and got the same result.
https://cad.onshape.com/documents/b2e0d255256b4b58e3069cb4/v/72197c6efeeefa9a32893872/e/7e17a85ffb7d844b62f04988
It looks like the "....."s that are in your drawing are 'sheet reference properties'
Because your sheet reference is the 'pin slot hinge' assembly, you can change these title blocks by changing the properties of the assembly itself (right click the assembly tab > 'properties...' > change title fields > apply)
Alternatively, if you want those title blocks to refer to the drawing tab properties instead of the assembly tab properties, you can change the reference to be a drawing reference:
Hope that helps. Let me know if you have any questions.
https://cad.onshape.com/documents/97aa8a9c3ed53d09eb929b11/w/fb92c1e0beab032aa55b3c97/e/416f9d1cb66d6fc3cd0acfdd
