Can't seems to query BodyType.POINT and BodyType.MATE_CONNECTOR separately
I made a test feature that tries to separate point bodies and mate connector bodies from a query that contains both, but looks like qBodyType doesn't filters points and MC's, and debug shows both body types simultaneously.
https://cad.onshape.com/documents/86e57adcf32da1e02e501076/w/b4948803110e67bebb9cd951/e/cc3cd72cb2890c2387d19d08
Test feature code:
Test feature code:
FeatureScript 675;<br>import(path : "onshape/std/geometry.fs", version : "675.0");<br><br>annotation { "Feature Type Name" : "Point query test" }<br>export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)<br> precondition<br> {<br> annotation { "Name" : "Query", "Filter" : EntityType.VERTEX || BodyType.MATE_CONNECTOR }<br> definition.q is Query;<br><br> annotation { "Name" : "Show points" }<br> definition.showP is boolean;<br><br> annotation { "Name" : "Show MC's" }<br> definition.showMC is boolean;<br> }<br> {<br> if (definition.showP)<br> {<br> debug(context, qBodyType(qEntityFilter(definition.q, EntityType.VERTEX), BodyType.POINT));<br> }<br><br> if (definition.showMC)<br> {<br> debug(context, qBodyType(qEntityFilter(definition.q, EntityType.VERTEX), BodyType.MATE_CONNECTOR));<br> }<br><br> });
I looked into this for you and it appears to be a bug in our system. I've logged it for you, thanks for pointing this out.
EDIT:
As reflected in the FeatureScript documentation, the MATE_CONNECTOR body type is only for filtering UI selections (as you've done in the precondition of your feature):
https://cad.onshape.com/FsDoc/library.html#BodyType
https://cad.onshape.com/FsDoc/uispec.html
If you would like to differentiate between mate connectors and other bodies you could use the following code:
Although it does seem like there should be an easier way to do this. Maybe raise an improvement request to get BodyType.MATE_CONNECTOR implemented for qBodyType(...).
In my case this behaviour of qBodyType means that my Curve generator feature relies only on the sort order of point and MC bodies inside the query ( possibly qBodyType affects on it). However, it somehow works
https://cad.onshape.com/documents/d8aab1e0e7ae10038a6830e0/w/9dfdd631d025960813b8f2df/e/ba4054f79173536a994fd0da
Maybe this can help with preserving ordering for you?
So if you have a query that's in the order you like (say, the original ordering from the definition, or some geometric sort constructed with `qUnion(arrayOfSortedPointBodies)`), you can intersect that sorted query with an unsorted query and an evaluation of the intersection will preserve the order of the first query in its input array.
thanks, i now trying to query mate connector created by feature pattern explicitly by its id.
I can get the id of original MC obtained as FeatureList with keys(), for example the id of feature pattern is (id+"applyPattern"), and it creates one instance of MC with instance name "patternedMC", but when i try to query that patterned mc by
qCreatedBy(keys(definition.mc)[0] + (id + "applyPattern") + "patternedMC") i see that query resolves to nothing. So is there any way to query patterned entity based on it of original id, feature pattern id and instance name?
As long as your feature pattern is regenerating correctly, try:
or just
if you want everything (all the MCs) created by the pattern.
You shouldn't need the original id at all.
