how do i get my design from onshape to a file that I can 3d print from?
boeck_allenboeck_allen Member Posts: 2
edited September 2017 in Community Support
I created a design on onshape and I want to get it to my 3d printer so I can make it. Can anyone tell me how to do this or point me in the direction of figuring it out. thanks in advance.
  • grochinogrochino Moderator, Onshape Employees, User Group Leader Posts: 44 image
    You can Export your design as an STL file, which should be able to be read by your 3D printer.
  • steven_abiusosteven_abiuso Member Posts: 11
    I had to google this one, but inside your drawing right click the Part Studio tab at the bottom and select export, then choose STL.
  • Dylan_StewartDylan_Stewart Member, Developers Posts: 107 PRO
    What slicer are you using? What type of printer do you have?
    Digital Engineering
    Or right click an a part and chose "export"...
