Export Drawings as Images
roryaronson
Member Posts: 24 PRO
Would be nice to be able to export drawings as .JPEG, .PNG, and .SVG images for better sharing on a website.
I will add you to the improvement request for this.
If you need a hi-res image why not export drawing as a PDF and use the browser's built-in PDF viewer, or an external PDF viewer?
Note: PDF supports multi-sheet drawings.
Too bad the functionality isn't present.
Install the free version of PDF Creator (https://www.pdfforge.org/pdfcreator)
Just "Print" your drawing in Onshape and choose pdfcreator as printer.
Then you can save as pdf, jpeg, png, tiff...
It is also possible to create custom profiles so you can save your settings.
I use it to save drawings in a special tiff format for one customer.
Transparent png works not so good with shaded views:
