create a variable by selecting points / importing variable from derived object
Hi,
I want to create a variable from a derived object by selecting 2 points of the derived object and calculating length
I'm new to onshape and the variable features and the way some tools like patterns works or simply extrude works is really awfull, variable can't be shared and so on... I would like either to import variables by selecting a derived object and create a popup list with all available variables, or create a variable by selecting two points and computing length... how can I achieve that in feature script? the best would be both...
thanks and regards
thanks and regards
https://cad.onshape.com/documents/77baa8153589a7fc5f289829/w/cffd0f2a7077380d5378a885/e/d3174bf5315e6aafcb889367
you can set some measured value of distance, length, angle, area or volume to a variable
